project curves??
project curves??
project curves??
there is a feature in solidworks called PROJECT CURVES...which is used to project 2 lines in different planes  with respect to each other. this feature i use to design cars in solidworks using blueprints( top-side-front-bottom view).
but sir iam not able to find this particular feature in fusion 360..
so plz help me sir.
im attaching the screenshot of that  tool from solidworks.
thqq
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
This item is located in our Sketch menu! What you first need to do is create a sketch on the new plane - the on that you want to project the curves to. Then, if you hit P (which is the keyboard shortcut) or navigate to the sketch menu and select Project, you can then project geometry or other sketch entities into the active sketch plane that you have.
Let me know if you need any more clarification!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
respected sir,
plz watch this video from 6:00 - 8:00.....you will get what i am asking
thanks for replying
https://www.youtube.com/watch?v=yFEYM_i0fkA
jeff_strater
I think what you want is Project -> Intersection Curve:
Jeff
Jeff Strater
Engineering Director
thqq sir that is exactly iam looking for.....
plzz add a direct shortcut for helix also in the next update
This works, but somehow I can't select a sketch as a whole, just the line or curve segment I click on is getting selected.
