project a sketch to multiple surfaces for a contiguous sketch
evanp4509U4JZ
evanp4509U4JZ
Can you project a single sketch to multiple surfaces so as to form  a contiguous sketch on those surfaces that can be used as a tool path?
jhackney1972
I am just taking a guess if this is what you are talking about.  Take a look at the Screencast.  Model is also attached.
John Hackney, Retired
evanp4509U4JZ
Thank you for the reply. That's not quite it. I'll clean up some of the clutter and load the file in a bit. Right now it is about 4 files dropped on top of each other in a quick and dirty attempt to test a process. What I have is a model of a trim fixture for a holster and a 2D sketch of the outline of the holster as a cut path.  The model is smaller than the outline to allow cutter clearance so I can't use the "3D Project" toolpath because there is no 3D under the trim sketch, only flat. So I wanted to use another model and project the trim sketch to that model.
