Project a sketch on a curved surface...
eric.thepaut3
Message 1 of 15
eric.thepaut3
Hello, sometimes it hard to search informations on the web. I want to project sketch lines on a surface. See picture.  Fusion can do it i know. But it does not allow me to do it. The sketch "Frette 25" should be projected on the fretboard face (curved) but i got an error Warning: Not support projecting sketch geometry into same sketch, please change the target sketch or geometry.
Though fretboard is not in the same sketch than frette 25
WTF?
My file : https://a360.co/2GyFa9U
This video is off topic i think... https://youtu.be/TOedgF0n4yQ
Replies (14)
Message 2 of 15
g-andresen
Split Face?
günther
Message 3 of 15
davebYYPCU
It means exactly what it says.
Project your source sketch - 2d geometry, into a destination 3d sketch that uses the surface and it is usually empty at the time we do this.
Two sketches, project 1st to 2nd.
Message 4 of 15
eric.thepaut3
Hi Gunther, yes it works but i have to make 21 split face operations. I saw i video (but i don't find it back) where he projected a sketch with the lines on the fretboard, but it did not work for me, and i don't remember why...
If i select all the lines as splitting tool i have an error "compute failed"
Message 5 of 15
eric.thepaut3
Please look at this video : https://youtu.be/6Kj8eS4fpsw
Except that he imports a dxf, he does exactly what i want to do, why can't i do it on my example? It's not from a sketch to a sketch, it's from a sketch to a an existing body's surface, and it does work for him...
Message 6 of 15
davebYYPCU
I stand by my advice.
That is an older interface and no timeline being used, and he is working in a 3d sketch,
Message 7 of 15
eric.thepaut3
OK, ok, i believe you, i'm just a newby. Older interface, sure, but 3d sketch? The sketch he creates on the offset plane above the fretboard is a 3d sketch? I just want to do it on my project.
Message 8 of 15
jhackney1972
See if this helps you.  Model is attached
John Hackney, Retired
Message 9 of 15
davebYYPCU
No, the source lines (blue ones) are in a planar (2d) sketch, and Finish that sketch. Sketch XX
With the Timeline on, creating a new sketch requires a plane to be selected, any one would do but is required.  It helps - not to select the same plane as the Sketch XX was made on.
Your new sketch when opened,  (is Sketch xx+1) is empty, then we select Project to surface, you select the surface, Fusion is then ready to Project the other sketch lines, you select them, hit ok.  By definition your purple lines are now conforming to the surface, the purple lines are not in the same sketch as the blue lines.
Warning message is talking about this process.
Not viewed Johns video.
Might help....
Message 10 of 15
eric.thepaut3
OK thanks man, it worked, but why can't i select those lines then to extrude for instance?
Message 11 of 15
jhackney1972
A single line does not create a profile to extrude as a solid or cut.  You should be able to extrude as a surface however.
Message 12 of 15
eric.thepaut3
Yeah sorry it was a stupid question...
Message 13 of 15
eric.thepaut3
Actually, i've projected also circles, and i can't select them... They are purple, and unselectable...
Message 14 of 15
jeff_strater
what do you mean you can't select the projected circles?  Can't select them at all, or cannot select them in, say, the Extrude command?  The latter is expected.  Extrude requires a 2D profile.
That the projected geometry is purple is also expected - projected geometry is always purple, which is how you tell it is selected.
Jeff Strater
Engineering Director
Message 15 of 15
Ajay_Kumar_Reddy
May be you are doing it  in a wrong way dear.
This video may help you.
