program opening message mystery
Fueler
Fueler
For  a while now I have been getting this message box on opening.
No clue what it is or what it is for.
Is this something the install routine should be taking care of?
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Fueler,
I believe this is for an add-in from our App Store called Visual Styles. Here is the link to the download. Is this something that you have downloaded in the past? A good suggestion to fix this error (or to delete it) is to first:
  • Enable hidden folders from Control Panel
  • Close Fusion 360
  • Navigate to C:\Users\<username>\AppData\Roaming\Autodesk\ApplicationPlugins
  • Delete the Visual Styles add in (let me know if it does not live in this folder and I will dig around for where it gets installed to - I believe all apps get installed here however).
  • If you want to - reinstall the add-in to see if it fixes that error message.
Let me know if that worked, thanks!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
