Hi All,
I exported the attached file as a STEP file to an engineering shop to bend the material and then cut the holes as specified in the drawing (50mmx10mm steel).
The shop has come back and advised that the curves on the model are splines (which is how I drew them) and asked if there is any chance I can send back as curves. They advise that a spline is a series of blended curves and because the curves are blended their software can’t define where the bend would start and finish.
Can anyone please let me know how I can fix my design so it is a curve? Getting the curve as specified took some effort and needs to be identical - the only way I knew how to achieve this was using the spline tool. Is the "Arc" tool correct one to use? If so how do I get the identical result?
I am a beginner with Fusion 360 and appreciate your help.
Thank you!
Solved by g-andresen. Go to Solution.
