The problem is the following (and I've looked on Google and didn't find a solution).
I draw a shape in Sketch mode, and then I realise I need to add some more segments to that sketch to change its form, but I have absolutely no idea on how to add lines to an existing sketch. All the info I find talks about curves and doesn't work with lines.
So what I tried is deleting some edges, and then trying to attach new lines to those edges, but that gives me 3D problems whereby the new lines are somewhere floating in space and not in the same plane as, nor connected to, the rest of the sketch.
I added some screenshots. The first one contains my sketch with a few linesegments removed (blue lines), and the second one is my attempt at adding new line segments, resulting in segments floating in space. When I am in "2D" view they look ok, but when rotating the camera you see they have a completely different depth offset.
