Problems with share public link dialogue
I have been having this problem with Fusion on my laptop and on my desktop machine, both the same symptoms.
When right clicking on a project in the bar on the left, selecting 'Share public link', it usually brings up a dialogue with the web URL to copy.
Instead, it is just bringing up a blank white box, which is impossible to quit out of. It just sits there in the foreground, and the only way to get out of it is to re start the program.
Usually, the second time round, it works.
This is a very repeatable problem, it happens every time on both machines.
Hoping that Autodesk know about this and is on the list of things to fix....
Pete.
lucasliraAU
Hello
Recently Fusion 360 has undergone updates on its interface, I'm not sure if this may have generated some conflict for this feature in its interface.
I recommend you do the reinstallation of the software interface believed that this can solve your problem. If the problem persists I recommend that you contact the support team directly.
In order for your actions not to be stopped, you can also join the A360 in order to get your public share link.
I hope these guidelines can help you with your work.
Greetings from São Paulo - Brazil!
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
