Hi folks,
I have been having trouble in creating a properly working revolute joint. I create the joint origins for each of the two components in the joint. Then as I try to create the joint when I go to select the components the program forces me to select faces on each component, and it does not let me select the components themselves. Then when I create the joint it ignores the joint origins that I previously created and it uses the faces I selected to position of the components, which screws everything up. Also, the first component will not revolve around the second one. I have provided a video so you can see what is going on: https://autode.sk/2zoDmfV
(Note: One question I asked in the video was why I did not have an "as built joint" option. But I found the answer to that in another post by someone else. I just turn on "capture design history" and then the "as built joint" option returns.)
Any help will be appreciated.
Vincent
