Problems while pattern joint components
carlos218689MC9
Message 1 of 8
carlos218689MC9
Hi, I'm currently working on a design, the issue is when I pattern or copy some jointed components,  the joint doesn't apply to the patterned components or the copied ones, once the copy or pattern has made I need to apply new joints, is there a way to make it faster? TIA
Replies (7)
Message 2 of 8
laughingcreek
can you post an example model?
-joints out side of a component don't copy with patter or copy components.
-joints in a component, ie an assembly, do copy. (meaning your copying/patterning the whole assembly)
Message 3 of 8
lichtzeichenanlage
Rigid joints? Just use Assemble -> Rigid group to join many components with one command.
Message 4 of 8
carlos218689MC9
mirror or pattern happen the same
Message 5 of 8
laughingcreek
works for me with copy and pattern, but not with mirror.  (honestly, not sure what I would expect mirror to do)
can you screen cast it with a copy or pattern?
Message 6 of 8
davebYYPCU
Yes there is the easy way - after Mirror, window select the new components and rigid group.
Might help...
Message 7 of 8
carlos218689MC9
Might help...
Thats what Im doing right know, but I was looking to save a step
Message 8 of 8
patilsm
Hi @carlos218689MC9 ,
Thanks for your Post.
Currently we are supporting Pattern and Copy-Paste joints with assembly but Mirror is not working.
Better you can use Copy-Paste or Paste New instead of Mirror so your joints also gets copied with component.
In mirror you need to manually added again that joints.
Sagar Patil
Sagar Patil
Software Engineer
Quality Assurance
