problems in F360 help / learning function.
Hi forum members.  i have been away from f360 for a month, and now i have returned apperently some changes have been made in the program i see.
I use to use the step by step tutorials in the help dropdown menu next to my name and becourse i wanted to pick up where i left of but they seem to have vanished, so i go further and click 'learn fusion' .  there i pick sketch corse that is what i want to learn, there i try both the 'aditional tutorials' button and the 'reference and documentation' button but both of them give me a new screen that does not react.  I do get a warning that autodesk.com does not react, with an option to restore the web page, i repetatly use this option but so far no luck. this problem is lasting for a week now and thats long enough for me to cal in the st bernards amongst you.  Many thanks on beforehalf.  greets Emiel.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Sorry to hear that this is happening to you. I just tried it on my computer, and everything seems to be working okay. I am curious if maybe Ad-Blocker or something along those lines is prohibiting a new window from popping up. Can you post a screenshot of what you are seeing?
Also, here is the link for Additional Sketch Tutorials and here is the link for Reference and Documentation. Do these direct links work for you, or are those broken as well?
Your question got successfully answered? Then just click on the 'Mark as solution' button.
James Youmatz
General Adoption Manager | Informed Design
Seems to be a Microsoft Edge problem for me in windows 10. some of the links in the resources section crash and freeze the browser.
hi. punking315,  Thanks for the swift reply, i have tryed to run the learning page in chrome and all is working fine again, many thanks emiel.
Hallo James, Thank you for the fast reply, I have tryed out the links you send me, they didnt work yesterday, but today everything go's fine.  thank you.
hallo punking 315,  yesterday i opened the learning content in crome and it worked fine, thanks for the hint.  today edge is healed again so problems are solved.
