Problems exporting DXF
Johan.Ekqvist
Johan.Ekqvist
Hello...
I have a really odd error, when exporting a *.DXF from a sketch Fusion has real problems to include radius of the part.
Then i need to restart fusion360, using the same sketch and exporting DXF the same way. It suddenly works?!
Supper annoying, anyone having the same issues?
Anyway, thx for a great software!
please see attachment
kate.raskauskas
Hi @Johan.Ekqvist,
That does sound odd. Is the radius export issue happening to just this sketch, or have you tried with other sketches? This spring another user posted on the forum about what may be the same error-- in that case it sounded like the specific sketch was the source of the problem, and it seemed to be solved by making a new sketch and exporting that. If this is the only sketch where you're getting the disappearing radii after exporting, I would try making a new sketch, projecting all of the old sketch components onto the new one, and then exporting the new one. If that doesn't work, please attach the sketch file (.f3d) and I'll take a look.
I'm glad you're enjoying Fusion otherwise 🙂
Best,
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
Johan.Ekqvist
Hello Kate..
Thank you for your reply..
I have done som testing and this problem affects different projects,components and different sketches.. i haven't found any constant in my troubleshooting, more then that the problem disperse when i have restart the software. The error comes back at different timelines, so i can work for 5 min or 4h before it´s back..
kind regards
kate.raskauskas
Hi @Johan.Ekqvist,
Thanks for the information. If you have any more specifics you can figure out, please let me know. In the meantime as it seems to be a sporadic issue, I'll log it with development.
Best,
Kate Raskauskas
Got the same problem and its only with part that have outline radius but a simple restart solves the problem its frustrating when i have a few parts ut and have to restart.
Johan.Ekqvist
Yea i still have this problem, tried different versions on fusion and both in Win7 and Win10
