Message 1 of 11
Problems creating fillet with variable radius
- Mute
- Permalink
- Report
I created a sketch and extruded it. Then I wanted to add a fillet with variable radius but this failes:
The startpoint and endpoint got a radius of 0.3 mm. In the middle I wanted to add 12 mm but this failes. š
Maximum radius which is working is 5mm.
For testing I duplicated the object and added a fillet with constant radius. And here I can create a 12mm fillet without any problem.
Why the variable radius does only work up to 5mm?
The f360 file is attached.
Thanks...
