Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Problem with step files
7 REPLIES 7
Message 1 of 8
rjeAT6XG
307 Views, 7 Replies
I'm trying to get a part quoted for CNC with JLC PCB.  The upload kept failing.  I contacted their customer service and they told me the problem was that the file contained multiple bodies.  When I open the same step in Fusion, it shows just the one body that I had intended to export.  Has anyone had an error like this?
I did try moving the body to the root of the file and deleting the empty component, but that doesn't seem to make a difference.
Also, I've made this part by cutting with another body.  I wonder if somehow that subtracted body is causing an issue.
Lastly, I can't share the file as this is proprietary company data.
7 REPLIES 7
Message 2 of 8
TrippyLighting
in reply to: rjeAT6XG
You should be able to share your fully expanded browser structure (screenshot) . If there are more than one bodies folder, with more than one body in it, then "they" are correct.
Message 3 of 8
rjeAT6XG
There is only one body shown.
Message 4 of 8
HughesTooling
When you export are you right clicking the Base Holder component and selecting export from the right click menu? This should give you a STP file with just the body. If you export from the file menu it might be reported as an assembly by other programs.
Mark Hughes
Owner, Hughes Tooling
Message 5 of 8
rjeAT6XG
Tried right-click export.  Same result.
I also tried to export as an iges, import into Fusion and export as a .stp, but that isn't successful either.
Message 6 of 8
TrippyLighting
And that is the entire browser?
Usually the root component of a design is not grounded to the parent, but your BASE HOLDER is.
Message 7 of 8
HughesTooling
@rjeAT6XG Have you tried a real simple test? Start a new design add just a box, no components, nothing else and export.
Mark Hughes
Message 8 of 8
rjeAT6XG
I have five other components that I've exported and they worked properly.  2 components from this same design.
