Message 1 of 10
- Mute
- Permalink
- Report
its my first post, but i found already many solutions here in this Forum for many problems i had, so i hope someone can help me out with my "little problem".
I am not sure if i found the right words in the title, but i think there is not much to explain, because if you look at the pictures below, you will understand my problem. I would like that the sheet metal body looks like on the first picture, but when i do the radius bend on the angled surface, the corners looks like you can see on the second picture.
I hope there is some quick trick for that 🙂
Thanks in advance and best regards,
Denis
