Problem with older Dokuments.
dennis-prinz
Observer Observer
dennis-prinz
Observer
Observer
I’m having a problem with documents I created in an older version of F360. These were still open for editing the last time I used Fusion in 2023. Now, after a break of several years, I wanted to have a go at F360 again and I can see that these documents are still open for editing. However, I can neither open and edit them nor close them.
I have the free Private version.
Can anybody help me?
RajkumarIlanchelian
There are two things you will need to do:
First:
  • The single-user-storage was removed  due to the Fusion Content Storage Standard.
  • Using your email used to register for Fusion ,please reach out to the team directly here - [email protected]
  • Tell them your hub is inactive and to activate it again
Second
once you have the hub activated again follow this article - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Files-stuck-in-Edi...
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
pkomatlapalli
Hello @dennis-prinz ,
Did the information provided by RajkumarIlanchelian help you and answer your question? If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information. If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Pavan Kumar
