Problem with long cylinder.
Onion7
Message 1 of 8
Onion7
Hi all, When I sketch a 3" dia. circle and then extrude it 16' into a cylinder, the cylinder will automatically change to a 14 sided cylinder!? It will not at shorter lengths, 2' for example. How can this issue be resolved? What am I doing wrong?
Replies (7)
Message 2 of 8
Bud_Schroeder_ADESK
Hi Luke,
Can you tell us what product you are using? Is this Fusion? Let us know and we will try and get you pointed in the right direction for help with your question.
Thanks and let us know.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
Message 3 of 8
Onion7
I'm using Fusion 360 on a powerful laptop.
Message 4 of 8
Bud_Schroeder_ADESK
Thanks for the update, we will move this post to the Fusion forum.
Hope the helps get you pointed in the right direction for help.
Bud Schroeder
Autodesk Inc.
Message 5 of 8
Onion7
Thank you! Your and the community's help is greatly appreciated!
Message 6 of 8
HughesTooling
I just tried and it works ok for me.
Can you get a screen gab and export the file as an f3d and attach here.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 8
HughesTooling
OK I've played with this a bit and I think I see what you're seeing if I zoom in, although it looks like there are flats it is still a circle if you measure it. I'don't think Fusion has any adjustments for display quality on this sort of thing.
Mark
Mark Hughes
Message 8 of 8
Onion7
I find it odd that this professional of a platform has issues like this. Possibly it has to do with keeping the processing power required for working in the model at a minimum. Autodesk needs to address this issue unless there is a sufficient reason.
Thanks for the input.
