pretty funny sketch bug
cekuhnen
Mentor Mentor
cekuhnen
https://drive.google.com/a/ckbrd.de/file/d/0Byzv_NlyKp_2U1lxeGEyQk40WGM/view?usp=drivesdk
stuff like this really should not happen ...
https://drive.google.com/file/d/0Byzv_NlyKp_2TW1kZGZLeUdKM1E/view?usp=sharing
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Phil.E
Claas,
I opened the file and couldn't find the sketch rectangle that turns into a line.
Can you post the file PRIOR to the bad effect?
FYI: a good bug report has A) repeatable steps and B) data that can be used to repeat the steps.
In this case, I don't have B. Please help.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
cekuhnen
Actually Phil, I saved and exported. Looks like Fusion messed up here.
Honestly with the amount of bugs(still heavy under dev so that makes sense) and the addition Fusion is in the cloud why not add a function
in Fusion like send file to dev for bug testing.
Maybe this could streamline things.
Claas Kuhnen
Phil.E
Claas,
Are you saying that you saved the file while it looked like this?  This is the state I need the file to be in. It does no good to look at data after the defect happens because that means it cannot be reproduced. It's already been produced at that point. 🙂
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
cekuhnen
yeah I saved and then exported.
Claas Kuhnen
cekuhnen
Phil
the detail is in the file the line you see is the collapsed sqaure - looks like when I hit export I saved the last stage.
I did a new square and then Fusion complained about not being able to constraint length wise a side
Then today made a new square did the same and it worked ...
But in the video you also can see that it did not work.
Claas Kuhnen
