Problem with lofting
peter_campbell103
peter_campbell103
I am trying to loft between two inclined planes each with an arch, with a curved top between the arches but flat bottoms ( an aircraft canopy). I get close to making it work but only one bottom side at a time will sit flat.   I have added a couple of screen shots in the attached doc.  I would be most grateful for any assistance.
Regards
Peter
Beyondforce
Hi @peter_campbell103,
Please attach the file and I'll show how you can solve this.
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
jeff_strater
@peter_campbell103, I think you are just missing one rail curve.  It's a bit hard to tell from the images, but it looks like you have two profiles and two rails selected (the top curved rail, and one of the bottom straight rails).  I think you may need to just add one more (the other straight rail):
But, as Ben says, if you can share your design here, we can take a more direct look at the model.
Jeff
Jeff Strater
Engineering Director
peter_campbell103
Hi Ben,
Thanks for your assistance - I found the problem!  I had the two side rails joined in the sketch of the base. Once I disconnected them the loft behaved.  Thanks again for your reply.
Cheers
Peter
peter_campbell103
Hi Jeff,
Thanks for your reply and your assistance.  I sorted it out as mentioned to Ben,
Cheers
Peter
