- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi community
I have a problem with the loft feature in autodesk fusion 360. I get the error "wire has self-intersection" or "coedges in a contiguous sequence are not vertex connected" depending on how i try to make my loft. Becouse english is not my native language i simply do not undestand these errors. I gather that the first one means i have something that intersect with itself but thats all i undestand. The wierd thing is i can make a sweep but not a loft.
What i am trying to do is make a trumpet that starts of as a square and ends in a circle. I made two planes at an angle to one another and drew a circle and a line on each of them. The point in which the two line segments should join i made a point and snapped to this point from both planes. As long as i only try to loft in one plane it works fine but when i try to loft over two planes it gives me the errors.
You can find my design here http://a360.co/1nQIkXX
What am i doing wrong?
Thanks for your help.
Morten
