I have a sketch I can extrude the whole sketch fine.
I want to add a 3mm offset and make that a separate extrusion, it fights me, I get maybe three points that are white dots, I have tried so many things to try and fix them. I do not see any breaks in the lines. but it will not select that area. If i start removing and adding lines it just doesn't seem to behave at all. things start moving and jumping around and the next thing i know its a mess. I have some inventor background but very old versions, there are things there to fix sketch problems but I can't find anything here.
If i do a big offset like 18 mm and i have match topology unchecked I can get a section that i can select. I have spent so many hours on what I think should be easy work but it just isn't
any help would be great.
