Problem with Fusion offsetting a somewhat complex sketch.
srunyon13KPGB
Message 1 of 8
srunyon13KPGB
I have a sketch I can extrude the whole sketch fine.
I want to add a 3mm offset and make that a separate extrusion, it fights me, I get maybe three points that are white dots, I have tried so many things to try and fix them. I do not see any breaks in the lines. but it will not select that area. If i start removing and adding lines it just doesn't seem to behave at all. things start moving and jumping around and the next thing i know its a mess. I have some inventor background but very old versions, there are things there to fix sketch problems but I can't find anything here.
If i do a big offset like 18 mm and i have match topology unchecked I can get a section that i can select.  I have spent so many hours on what I think should be easy work but it just isn't
any help would be great.Screenshot 2025-03-08 194551.jpgScreenshot 2025-03-08 194700.jpgScreenshot 2025-03-08 194828.jpgScreenshot 2025-03-08 194939.jpg
Replies (7)
Message 2 of 8
g-andresen
1. an offset with activated “match toplogy” is only possible to the extent that there is no self-intersection between vectors.
2. white dots indicate open vectors > breaks
3. the offset can be omitted if you select the “Thin lines” option during extrusion and then extrude the desired sides to “their” height.
günther
Message 3 of 8
g-andresen
The devide and conquer method helps to detect breaks.
günther
Message 4 of 8
johnsonshiue
Hi! Another approach to consider is to extrude the sketch as a surface body. Then create an offset surface from the extruded surface. Or thicken the surface to create the thin wall.
Many thanks!
Software Test Engineer
Message 5 of 8
srunyon13KPGB
Thanks but I'm not sure how to do either but I will try.
the thing is I want the gap around that piece so I would extrude only the outer, its like trying to make a box with a gap for the inner piece and then later a lid out out of the same drawing.  I think if i extrude each face it would get really hard to manage.
Message 6 of 8
srunyon13KPGB
When selecting thin line it will not extrude at all. it fails.
I do not have Match topology checked and it still fails except when I make the offset much bigger.
When I zoom in on those dots , yes hey look connected, how do I fix them? Adding new lines just don't work.
What I'm trying to do is to have that gap around the inner piece .
it just seems so close to doing what I want .
thanks for your help.
Steve
Message 7 of 8
TheCADWhisperer
@srunyon13KPGB
I only completed part of the spline as a demonstration, but I think it will work as one continous spline.  You can adjust handles if needed but first try without adjusting handles.
Message 8 of 8
srunyon13KPGB
Thanks but i ended up working on the dfx file i importated and that may fix the issues
