i use on my design 2mm sheet metal.
I decided to add a 2.5mm body and convert it on sheet metal.
The problem is that although i added this thickness on current design sheet metal rules i get the following error
Solved by patilsm. Go to Solution.
Hi @an18211821 ,
Thanks for your post .
I have checked your workflows, where you have sheetmetal component with 2mm Thickness rule and you adding new body into that component with 2.5mm thickness and trying to convert that Body to sheetmetal and you getting Error Message what you shown in attachment.
If same workflows If you trying then Error Message is expected because If your component rule have 2mm thickness you trying to convert the body have thickness 2.5 mm in same component then its not supporting because your rule have 2mm thickness.........it only allow you to convert If you change thickness of your component to 2.5 mm or you need to move that body to new component have 2.5mm thickness rule.
Please let me know If you expecting other that this .
Sagar Patil
