Problem with conversion of design to drawing
I have a problem with the extraction of drawing from design which I have created.  I have attached my file in this message for reference.
catot
What is the problem exactly? I'm able to create a drawing from it.
Can you send the length or component called "Rubber Strap" as a jpg or pdf.  As I can't able to extract.
If you get the drawing file, please send even that.  I think there might be a problem with the software I have.  It should be rectified
Thanks for your help.  I have saved in other file then I have resolved my problem
