I have a 2d map of a lake. The map have height curves.
I create a 3d map and use a closed splines for every meter.
The work method is:
1. I have a 2d picture in background.
2. Create a sketch on a plane.
3. Create splines that follow the height curve.
4. The spline goes around all the lake and attach were i begin. If i have luck the spline curve lightning yellow and i can use it to extrude or cut.
5. Sometimes or very often the spline will not lightning yellow when i close it and i can not use it for extrude or cut.
6. I save the file and exit.
7. Open the file again and now the closed spline curve lightning yellow?. When i try to extrude the spline it works but i get an error message. Se picture.
8. When i later try to use the extruded body, i can not use "combine and cut" tool. So the body is not ok.
Are there any inspect tool i can use to find the problem with spline?
