Problem with changing units
I noticed an issue with changing the units within a design.
I have my default using as millimeters. I changed the units for on specific design using the Units button under Named Views (see image) to cm for one particular design. When I exported the body as an STL and measured it, it was 1/10th the size- none of the cm units stuck and everything went back to mm (ie- the height which was supposed to be 35cm measured to be 35mm)
Am I missing something? If not, can this be explored for future enhancement.
Thanks!
TheCADWhisperer
You must also verify the correct export units when saving an stl.
Oops.  Let me dig a bit deeper.
