Problem re-sizing components
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
In the attached documented I extruded the main shape and then split the body into the two components. The idea being they will then be fixed back together via the captive nuts in the face plate.
After I started 3d printing the face plate I realised the gaps between the nuts and the walls are too small and so need to resize the whole thing. I did a push pull on the long edge faces of the face plate and that has worked fine, but when I try the same on the main case it doesn't pull the corners out with it, and if I do that separately it ends up misshapen.
Have I made a mistake early on thats causing me issues now. Do I need to start again? I would also like to move the nuts and bolt holes, but that seems much harder. I have some construction lines, but they are in one sketch and I cant seem to use them in another
