Problem on body deletion
odolyte
odolyte
Watch  :
https://screencast.autodesk.com/Main/Details/3f06a885-b3f2-46e6-af24-d1be0f4af8f8
then
https://screencast.autodesk.com/main/details/8bc44fb2-cd7b-4664-baa6-2b6ab5aa60b9
The deletion of the unnecessary part does not work, you are thrown back before the last action in the timeline (before split or cut).
Moebius Factory
KirillChepizhko
Instead of delete command, try using remove, right below Robot wink
odolyte
Thx it works!
But this is crazy UI. It used to work with deletion and this was simple !
What's the point of deletion then if you have to "remove" them in order to delete the pieces ?
Moebius Factory
keqingsong
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
