Problem moving imported object
I encountered problem moving imported components to the origin. I have a scanned object called Lizard3. when I import it using "Insert Into Current Design", it automatically placed very far from the origin. When I try move it to the origin by using move command - I choose move point to position option and choose the root origin point (you can see that the object and the root origin point are selected in the screenshot) - The Ok button is disabled. What did I wrong, and how can I move imported object to the root origin? (I tried also unlink the imported object, but it also didn't work)
Thanks a lot!
jeevesme
I believe in order to use the point to position move, you need to type in the coordinates to where you want the point to be......   ie x:37mm y:94mm z:136 mm
_________________________________________________________________________________________________________________________________________Forever yours,
Love,
Brian
PS. If this answered your question, please mark as answered so others do not read through the posts trying to figure out if it was answered.
HughesTooling
You have 2 problems. First problem is you have point to position backwards,  point to position you need to select a point on the object you're trying to move then enter the coordinates of where you want to move too. Your second problem is you can't select points on a mesh. Think the only option with a mesh is just dragging, Fusion isn't the right program if you're going to work with meshes.
Mark
Mark Hughes
Owner, Hughes Tooling
