Problem lofting Airfoil Wing
achaval.lucas
achaval.lucas
Hi guys!
I am having problems when trying to loft my wing. I have an airfoil profile and a point that I'm trying to loft with two rails. When I select the first rail, everything goes well, but when the second rail is selected, I get a warning: The loft would intersect itself.
I upload a simple screencast and CAD File, so that you can understand it precisely.
Thanks a lot!
Lucas.
mavigogun
There's a problem with your profile- the lines at the trailing edge overlap each other, creating a self intersecting surface when lofting.    On a separate note, why so many spline points?     You should be able to achieve a close/identical curve with far fewer points.
I created a two-spline profile and successfully lofted along your rails; it seems something is amiss with your profile.
achaval.lucas
Thanks a lot! Very helpfull.
mavigogun
If possible, take care to connect the rails at the extremes of the cord profile.
achaval.lucas
I´ll do it. Thanks again.
