I found a tutorial on using the tangent restraint to make circles tangent but it changes the size of the circle. Is there a way to "move" a fixed diameter circle to become tangent with another circle or line? I make trim patterns and we use a common radius on all the corners and frequently have "steps" and reversals where I used to just make 2 tangent circles and then run a tangent line off to the next direction change. The fillet corner command works well for line corners but I can't seem to get it to work where I have, say, a .3" offset in a pattern over a .5" distance and we use a .25" radius on all the corners.
