Problem jointing to an angled hole
SFL-Chimneys-Jason
Message 1 of 11
SFL-Chimneys-Jason
I created a radial pattern of holes around a cone which I then extruded.  The holes are rivet positions for another component.  The problem is that I cannot join the two components using their respective holes, basically, I do not get a snap/location point in the center of the angled hole on the cone.
Grateful for any advice.
Replies (10)
Message 2 of 11
TheCADWhisperer
Can you File>Export your *.f3d (or f3z) file to your local drive and then Attach it here to a Reply?
Message 3 of 11
SFL-Chimneys-Jason
No problem.
Message 4 of 11
TheCADWhisperer
@SFL-Chimneys-Jason
Your sketches are not fully defined - so I will have to start over from scratch.
Could be a while... ...check back later.
Blue lines and white dots should keep you awake at night.
Make use of obvious symmetry about the Origin.
I would use Sheet Metal tools for sheet metal parts.
Sketch can be simplified.
Material is not uniform Thickness?
How will this cone be manufactured without Bends and without uniform thickness?
Will it be three pieces welded together?
How will this angle be measured in the real world?
Why is it not the same angle as the Terminal Leg?  Is that intentional?
Message 5 of 11
davebYYPCU
The Joint works as expected, here.
Other things in the timeline are a little left field.
You have to select the leg first, as the cone can't move.
Might help....
Message 6 of 11
jhackney1972
To answer your direct question, you can use the inside wall of the hole, on the tapered side, as your joint origin snap point.  The video will show what I mean.  As the @TheCADWhisperer mentions, you could improve on your model technique.
John Hackney, Retired
Message 7 of 11
SFL-Chimneys-Jason
No joy on my end, I must be doing something wrong or have an incorrect setting.  I have attached a screen capture.
Thank you for your support.
Message 8 of 11
SFL-Chimneys-Jason
Thank you so much for your reply.  You are correct, the sketches or design is not perfect, it is more a quick visual concept I was putting together, more than a production stage design.
Message 9 of 11
SFL-Chimneys-Jason
Thank you John, that worked a treat. Thank you to everyone hot your help and support.
Message 10 of 11
TheCADWhisperer
@SFL-Chimneys-Jason wrote:
...it is more a quick visual concept I was putting together
@SFL-Chimneys-Jason
It would have been quicker to do it right than to do it the way you did it.
You are doing too much work.
I thought maybe you would want to learn the right (efficient) way.
Message 11 of 11
SFL-Chimneys-Jason
Your comments and instructions are valuable and wise.  I certainly do want to learn the best workflow and appreciate your feedback and instruction, especially while I am learning.
Many thanks, Jason
