Problem in selecting the sketch to convert it to a body
Message 1 of 11
Hi all guys, I ask you for help to solve this problem, I made a container using sketch and I would like to transform it into a solid body using the "Revolve" command, but when I try to select the center of the sketch nothing happens, practically it is impossible for me to select it. I checked if there were any non-junction points, however everything seems to be fine.
I attach the link of the object to understand how to solve the problem.
Thank you
Link
Replies (10)
Message 2 of 11
davebYYPCU
Sketch has no profile, (blue shading inside the lines)  Wont work until fixed.
Your sketch has white point intersections
Your sketch is not fully constrained.
Divide and conquer shows one hole here, did not check for others.
Might help.....
Message 3 of 11
MoshiurRashid
Hi
Thanks for posting. I've checked the sketch. It is not well defined. Even most of the elements (line, arcs) are not connected in "coincident" constrains. I could fix them one by one but that is creating dimensional inaccuracy. So, it should be done by your requirements.
Please, drag the sketch end points and those points which moves, use Coincident constrain to connect them and then check the dimensions those are required.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 4 of 11
Forgive me, but I went to see where the hole you indicated was and I found nothing.
Link Video
Message 5 of 11
g-andresen
Maybe you're right.
But the unclosed vector does the same thing.
günther
Message 6 of 11
davebYYPCU
You cant "see" it.  You have not got blue shading, I do.
You can find it with temporary lines.
Message 7 of 11
Ok, I saw ... but now how do I solve the problem at that point?
Message 8 of 11
g-andresen
did you realize what I show?
günther
Message 9 of 11
davebYYPCU
Easy way is Sketch > Extend Tool or Sketch Trim
Almost easy way is Window Select Points and Make them coincident.
Might help....
Message 10 of 11
yes yes I saw what you showed me, but I don't know how to intervene to fix the problem
Message 11 of 11
g-andresen
White dots are not your friends!
günther
