Coming from SW this is my first project using Fusion 360.
I am trying to model my house and I am stuck on how to position a set of windows on a "curved/segmented" wall, see image below. Started my window component on the left window as shown below I'm able to position it exactly how I want using sketch relations. My problem is with the other windows.
Making a copy of the first window component I now have to use Joints to position my second window. In SW I would make a coincident mate between the two side edges, and another mate to make the front faces parallel.
The first 'mate' I recreated using a Revolute-Joint between the two edges. My problem is on how to define that last degree of freedom (the rotation). Using a "parallel mate" would solve this but after watching numerous videos and websites I am still out of luck.
