problem designing connecting part
i designed this part no problem but now i need to design the part that sits on top of this one and i cant figure how to get it to contour to this part. please advise!
thanks
davebYYPCU
We need more information, I can't tell what is going on top of the model you did there.
Photo or description, how it goes on top?
jeevesme
Yeah, its a bit hard to give you ideas without knowing how your part is going to be attached.  Here are a few way to capture the contour of the base though:
_________________________________________________________________________________________________________________________________________Forever yours,
Love,
Brian
PS. If this answered your question, please mark as answered so others do not read through the posts trying to figure out if it was answered.
jeff_strater
Another technique you can use is the Combine tool - use your existing component to subtract from a new component in a way that will guarantee a fit:
Hope this helps,
Jeff
Jeff Strater
Engineering Director
ok so that helped out a lot i am almost done with the part but can not get the final 2 inch by 1/2 inch deep hole in the middle of the design to appear see attached photosScreenshot (10).pngScreenshot (9).png
please advise
daniel_lyall
Just for a test change the direction of the hole hit flip direction if it does not fail the hole refrences is under the top of the model
Change to extrude and use 2 sided, it does look like it's under the top pull up a little bit and if the hole is there that's it.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
