How to turn off reassociate warning in Fusion 360
Aadithya01
Advisor Advisor
Aadithya01
Can anyone show me how to turn off the reassociate error in Fusion 360 in drawing.
http://autode.sk/2luiBrc
Kindly watch the above link where I have shown the problem. Usually we use the command ANNOMONITOR in AutoCAD to turn off that warning . Is there any setting in Fusion 360 to turn off that error?
cmiller66
Hi Aadithya01,
The short answer is we do not have a corresponding ANNOMONITOR setting exposed in Fusion 360 drawings.  When you fillet those edges and update the design, ideally those dimensions would remain associated (no icon) but those warning icons are there specifically to let you know the dimension is no longer associated with the view and will not update with the drawing view if additional design edits (say a presspull of the length of the part) are made.  If you right-click the badge you have options to delete or re-associate.  The intent would be to keep the dimensions associated to the views to make sure the values reflect those in the design.
I will check with the team on how/if we can better handle that type of edit in the design to retain the dimension's associativity.
Chris
john.ed.ravensbergen
Community Visitor
Community Visitor
A way to turn this off would be great.  Especially when using sketches in drawings.
