Problem creating a fillet
timjamesbrennan
timjamesbrennan
Hello, I need some help please. I am modelling a school chair and the fillet command keeps failing - I am not sure how to proceed. Please see the screencast below. Thanks!
https://autode.sk/2PV4esX
g-andresen
Please share your design  to take a look at how the different bodies interact.
günther
Johnc911
Here is an alternate approach to that chair. This is not a complete solution, but it might give you ideas on an alternate way to approach this. I'm not sure this is correct to describe your exact design, but the correct approach (I believe) will be something very similar to this. If you go with this method, I'd like to see where you take it.
timjamesbrennan
Thanks. Please see file attached
timjamesbrennan
That does look close to what I need. The thing that I am not sure how to add though are the edges which bend at 90 degrees to form a lip.
davebYYPCU
Sketch the edge profile, and sweep it around the body edge.
Might help....
