Problem after projecting into present design
Message 1 of 10
I am a newbie to CAD and Fusion 360. I have inserted a design into my present design and I now need to reference the inserted design geometry to build parts onto it but I cannot project the geometry. Furthermore I cannot form joints onto the inserted item.
Any help greatly appreciated
Replies (9)
Message 2 of 10
mango.freund
please enter the type of your design. is it dxf - svg - other?
with right click on the purple projection lines you can select "loosen link". after that the lines are blue and completely free to manipulate.
Message 3 of 10
g-andresen
please share the file
File > Export > save as f3d on local drive > attach to next post
günther
Message 4 of 10
Attached are the 2 files of the Irish Jaunting cart I am working on.
Message 5 of 10
davebYYPCU
Both files appear to be normal, one empty sketch with an error.
What is it you can't do?
Message 6 of 10
I need to attach fittings to the shafts. eg. the metal collar shown by one of the arrows. To do this I need to reference geometry from the shafts but I cannot project the shaft on to the plane in my design. Attached is the plan with items marked with red arrows.
Message 7 of 10
mango.freund
hi - @Anonymous   you have to unlock the body see picture. right click and unlock.
greetings mango
Message 8 of 10
mango.freund
your outer contours are not straight / flat so you cannot click them directly. an offset plane is the solution. see image. but if you project a surface onto it and do it with a combination of "it will work."Unbenant.PNG
Message 9 of 10
mango.freund
@Anonymous projecting is probably possible with a 3D contour.
Message 10 of 10
Thank you for your replies and help. Unfortunately I have not had time to try them out. I will let you know how I get on when I do.
