Print Studio
Print Studio
pope_nicholas
Print Studio
pope_nicholas
Can you please add support for "Custom" printers with the ability for port/baudrate settings.
Thank you
I_Forge_KC
With some JSON editing you can already do this.
For example, if you modified or duplicated the Printrbot Printer, you could change the baud rate (and the port is selected during the connection process).
2017-02-23 16_00_45-C__Users_Kenny Cornett_AppData_Local_Autodesk_Print Studio_printDB_printerTypes..png
K. Cornett
Generative Design Consultant / Trainer
pope_nicholas
Right i tried that all i get is "connect to a USB printer: plug it in now" the printer is plugged in and works fine via cura (had it over a year) its on USB-Serial CH340 (Com6) @ Baud 115200.
I changed the baud to 115200 but nothing, honestly I haven't messed with JSON files before I did copy the original just in case though.
I_Forge_KC
What printer is it and what firmware variant?
K. Cornett
pope_nicholas
Hi sorry it's taken a bit to reply my printer is a ANET A8  running marlin
Thanks Nic
Would you tell me more in detail ?
