Print Studio doesn’t start? Delete these folders
dutkayd
Alumni Alumni
Message 1 of 23
dutkayd
Here’s what I did when Print Studio decided to crash on start:
Uninstalled Print Studio completely,
Deleted the data from C:\Users\username\AppData\Local\Autodesk\Print Studio, and also from C:\Windows\System32\config\systemprofile\AppData\Roaming\Autodesk
Made sure there was no Print Manager service left in Windows Task Manager > Services tab > Services button. I right-clicked Stop it,
Re-installed Print Studio.
When I had Print Studio connected to a print manager on another computer and could not access it, I asked an Admin to delete the registry key on Windows (or plist file on Mac). Don’t try it if you’re not an expert.
Registry key on windows:
HKEY_CURRENT_USER\Software\Autodesk\Spark or HKEY_LOCAL_MACHINE\Software\Autodesk\Spark
Plist file on mac:
$HOME/Library/Preferences/com.autodesk.Spark.plist or /Library/Preferences/com.autodesk.Spark.plist
I hope this helps.
Replies (22)
Message 21 of 23
This worked, thank you!!
Message 22 of 23
bryanbry77
Observer
Observer
wsteinkeR5PB9 post fixed the issue!!! Many thanks, I was just about to give up on the Program.
Message 23 of 23
When unistall started the program asked if I wanted to reinstall.  I oped for that...no more problems.
