Print Setting Library
In the print setting library I have selected PLA 1.75mm , 0.4mm Nozzle FFF.
I note on the right under info Technology FFF , Layer Height 0.2mm, Extrusion Width and all the others have not been assigned. Does the information need to be there or will this be the default setting.
I appreciate your feedback as I'm trying to learn.
Thanks a lot.
pendean
Community Legend
Community Legend
Which software are you using? You selected a forum that is not focused on that.
serge.quiblier
Hello @Anonymous
When you edit the print settings, either in the library, or from the operation you should have something similar to this :
If you don't have this kind of display, then are you using Fusion in a non-English language?
Can you provide a screen capture of what you got, please?
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
