Print Drawing
Print Drawing
Print Drawing
I really appreciate the new Print Drawing feature, is there a way to add a 1:1 scale option?
fuqiang.li
Community Visitor
Community Visitor
Hi mcgp2017,
Thanks for your post.
The Print Drawing feature tries to match paper size in printer with the sheets as much as possible. If there is a matching size paper in the printer, the sheet will be printed with 1:1 scale. Otherwise, it will be scaled to the default paper size in printer.
If this is not happening in your machine, then it is bug. Or, are you looking for a different functionality? Would you mind to share more?
Fuqiang
