I need to print a drawing full scale to use as a template. The actual size of the part is 630mm wide x 200mm high. When in drawing if I select paper size of A4 I only get one corner of the part. If I chose A1 the part fits but when I export to a pdf it is only one sheet so I can not tile the page when I print it.
Is there some other thing or way I should be doing this?
