Print drawing 1:1 scale on multiple A4 paper when drawing is A1 size.
burnandreturn
burnandreturn
I need to print a drawing full scale to use as a template.  The actual size of the part is 630mm wide x 200mm high.  When in drawing if I select paper size of A4 I only get one corner of the part.  If I chose A1 the part fits but when I export to a pdf it is only one sheet so I can not tile the page when I print it.
Is there some other thing or way I should be doing this?
g-andresen
PDF  > print > Size (real size) >poster
günther
