Prevent joints to animate simultanously
batgaze
Observer Observer
batgaze
Observer
Observer
Hi guys,
I'm working on following assembly: basically, an arm spins around an axis, and on the arm an actuator moves in a translation motion.
Except these two joints, any other joints in the assembly is rigid.
The two joints works correctly, but when I move one by dragging, the other is also animated.
I'd like to prevent this behaviour and to be able to move each join separately.
Despite a lot of googling I can't figure this out, any help would be higly appreciated 🙂
g-andresen
please share the file for reply.
File > export > save as f3d on local drive > attach to post
günther
batgaze
Observer
Observer
Done
jhackney1972
Probably the only way to achieve this is to select the Slider Joint, right click on it and select Lock Motion.  When you want to release it, select the Reset Position icon to place your assembly back into the starting position which will unlock the Slider Joint automatically or you could unlock it manually.
John Hackney, Retired
