Prepping for 3d printing. Is there a quick way to do it?
richard_markham
Observer Observer
richard_markham
Observer
Observer
I have a fusion 360 assembly drawing consisting of about a dozen parts which I want to 3d print.
What's the easiest way to rearrange the parts into the correct orientation to 3d print? Do I just do this manually or can fusion360 automate this?
rushabhthakkar_910
Can you elaborate your issue..?
Do you want to re-arrange the parts in the drawing..?? Or something else..?
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
wersy
Depending on the complexity, I would consider splitting it up for better printing.
TheCADWhisperer
I am not sure the issue is fully explained.
As I read it:
1. Best print is dependent on relation of Z-axis of the part, so for an assembly it is beneficial to reorient the "bottom" of the part to the platen such that Z is in best layer printing orientation.
2. When printing multiple components (in same print session) of an assembly - you probably don't want to print "as assembled", but rather oriented as in #1 and perhaps in X,Y layout as well.
My slicer does this (but I have access to a $65k printer).  Actually it is only partially automated - still have to tell the slicer what you want.
I do not know of an automatic tool for this operation.
You will have to reorient the components prior to sending the the slicer software if your slicer software does not have this functionality.  Fortunately - it is pretty easy to do.  If you have trouble - Attach your *.f3d file here.
richard_markham
Observer
Observer
OK, so I do have to manually break the assembly apart and re-orientate for 3d printing. I am a total newbie to fusion 360, so before I start doing this, I just wanted to check there wasn't some automatic method to do this.
Thanks for your help.
rushabhthakkar_910
There is no way that can do this for you. You'll have to manually do it.
Thanks and Regards,
Rushabh Thakkar.
etfrench
Simply send each component or body individually to the slicer and arrange them there.   There is no need to break an assembly apart.
Note: I usually just save each body as an stl (or 3mf) and send those to the slicer.
ETFrench
