- Mute
- Permalink
- Report
Hi, this will be my most complex project by far, and before committing dozens of hours to it I was hoping to get some feedback on my proposed workflow.
I will be modelling and machining hundreds of plywood sheets to essentially make a flatpack bouldering gym. Not the gym in question, but here is a picture of something similar. I currently have an Inventor model of the front surface of the wall, and my job is to break this down into individual plywood sheets, mark where to cut them, and drill the holes to mount the climbing holds and pilot holes for attaching to framing.
The inventor model (apologies, I don't wish to show the whole model)
My proposed workflow:
- Give each flat section depth, as a body
2. Fill in any gaps from open corners (push/pull rather than extrude, to keep the same 'plane')
3. Pattern holes across each of these bodies
4. Manually lay out plywood sheet sizes across each body
5. Extrude a new body from each of these sketches
6. Offset a construction line and mark sketch points to pattern a hole for pilot holes to screw to frame. (is there a quick way to do this?)
7. Extend these bodies to allow room to make a shallow hole to indicate where these pieces should be cut
And finally, use the nest feature to calculate all my machining (obviously a big one, but want to make sure I'm starting with a good base for this before I spring for the extra credits.)
Does this sound workable? What are some best practices I should keep an eye on? Labelling everything is a must, of course, and I'll have to figure out when to use bodies and when to use components.
Any input would be appreciated- How would you go about this?
