- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am new to Fusion 360 so please forgive me if this is posted in the wrong place. I am trying to make a vacuum hold down table for my 6040 Router. My workflow is as follows. 1. I create a new sketch 2. select a plane 3. draw a center rectangle 4. size the rectangle 18.75 in X 14.25 in 5. extrude rectangle to .75 inch 6. use hole command create hole 7. use pattern command and choose rectangle make 28x36 hole .50 apart get warning too many pattern instances press ok anyway warning goes away and I have 1008 holes on my rectangle. 8. I switch from design to Manufacture 9. Choose new setup Setup is Generic 3 Axis milling, Orientation Select Z axis plane x axis, orgin selected point, stock set to relative. click ok. 10. choose drill, the hole hole making drill tool is 3/16 11. choose geometry diameter range tool path is shown click ok 12. Post process LinuxCnc my gcode %
(1001)
(MACHINE)
( VENDOR AUTODESK)
( DESCRIPTION GENERIC 3-AXIS)
(T3 D=0.1875 CR=0. - ZMIN=-0.75 - DRILL)
N10 G90 G94 G17 G91.1
N15 G20
N20 G53 G0 Z0.
(DRILL2)
N25 M9
N30 T3 M6
N35 S5000 M3
N40 G54
N45 G0 X0.5 Y0.75
N50 G43 Z0.64 H3
N55 G0 Z0.24
N60 G98 G81 X0.5 Y0.75 Z-0.75 R0.2 F39.37
N65 X1.
N70 X1.5
N75 X2.
N80 X2.5
N85 X3.
N90 X3.5
N95 X4.
N100 X4.5
N105 X5.
N110 X5.5
N115 X6.
N120 X6.5
N125 X7.
N130 X7.5
N135 X8.
N140 X8.5
N145 X9.
N150 X9.5
N155 X10.
N160 X10.5
N165 X11.
N170 X11.5
N175 X12.
N180 X12.5
N185 X13.
N190 X13.5
N195 X14.
N200 Y1.25
N205 X13.5
N210 X13.
N215 X12.5
N220 X12.
N225 X11.5
N230 X11.
N235 X10.5
N240 X10.
N245 X9.5
N250 X9.
N255 X8.5
N260 X8.
N265 X7.5
N270 X7.
N275 X6.5
N280 X6.
N285 X5.5
N290 X5.
N295 X4.5
N300 X4.
N305 X3.5
N310 X3.
N315 X2.5
N320 X2.
N325 X1.5
N330 X1.
N335 X0.5
N340 Y1.75
N345 X1.
N350 X1.5
N355 X2.
N360 X2.5
N365 X3.
N370 X3.5
N375 X4.
N380 X4.5
N385 X5.
N390 X5.5
N395 X6.
N400 X6.5
N405 X7.
N410 X7.5
N415 X8.
N420 X8.5
N425 X9.
N430 X9.5
N435 X10.
N440 X10.5
N445 X11.
N450 X11.5
N455 X12.
N460 X12.5
N465 X13.
N470 X13.5
N475 X14.
N480 Y2.25
N485 X13.5
N490 X13.
N495 X12.5
N500 X12.
N505 X11.5
N510 X11.
N515 X10.5
N520 X10.
N525 X9.5
N530 X9.
N535 X8.5
N540 X8.
N545 X7.5
N550 X7.
N555 X6.5
N560 X6.
N565 X5.5
N570 X5.
N575 X4.5
N580 X4.
N585 X3.5
N590 X3.
N595 X2.5
N600 X2.
N605 X1.5
N610 X1.
N615 X0.5
N620 Y2.75
N625 X1.
N630 X1.5
N635 X2.
N640 X2.5
N645 X3.
N650 X3.5
N655 X4.
N660 X4.5
N665 X5.
N670 X5.5
N675 X6.
N680 X6.5
N685 X7.
N690 X7.5
N695 X8.
N700 X8.5
N705 X9.
N710 X9.5
N715 X10.
N720 X10.5
N725 X11.
N730 X11.5
N735 X12.
N740 X12.5
N745 X13.
N750 X13.5
N755 X14.
N760 Y3.25
N765 X13.5
N770 X13.
N775 X12.5
N780 X12.
N785 X11.5
N790 X11.
N795 X10.5
N800 X10.
N805 X9.5
N810 X9.
N815 X8.5
N820 X8.
N825 X7.5
N830 X7.
N835 X6.5
N840 X6.
N845 X5.5
N850 X5.
N855 X4.5
N860 X4.
N865 X3.5
N870 X3.
N875 X2.5
N880 X2.
N885 X1.5
N890 X1.
N895 X0.5
N900 Y3.75
N905 X1.
N910 X1.5
N915 X2.
N920 X2.5
N925 X3.
N930 X3.5
N935 X4.
N940 X4.5
N945 X5.
N950 X5.5
N955 X6.
N960 X6.5
N965 X7.
N970 X7.5
N975 X8.
N980 X8.5
N985 X9.
N990 X9.5
N995 X10.
N1000 X10.5
N1005 X11.
N1010 X11.5
N1015 X12.
N1020 X12.5
N1025 X13.
N1030 X13.5
N1035 X14.
N1040 Y4.25
N1045 X13.5
N1050 X13.
N1055 X12.5
N1060 X12.
N1065 X11.5
N1070 X11.
N1075 X10.5
N1080 X10.
N1085 X9.5
N1090 X9.
N1095 X8.5
N1100 X8.
N1105 X7.5
N1110 X7.
N1115 X6.5
N1120 X6.
N1125 X5.5
N1130 X5.
N1135 X4.5
N1140 X4.
N1145 X3.5
N1150 X3.
N1155 X2.5
N1160 X2.
N1165 X1.5
N1170 X1.
N1175 X0.5
N1180 Y4.75
N1185 X1.
N1190 X1.5
N1195 X2.
N1200 X2.5
N1205 X3.
N1210 X3.5
N1215 X4.
N1220 X4.5
N1225 X5.
N1230 X5.5
N1235 X6.
N1240 X6.5
N1245 X7.
N1250 X7.5
N1255 X8.
N1260 X8.5
N1265 X9.
N1270 X9.5
N1275 X10.
N1280 X10.5
N1285 X11.
N1290 X11.5
N1295 X12.
N1300 X12.5
N1305 X13.
N1310 X13.5
N1315 X14.
N1320 Y5.25
N1325 X13.5
N1330 X13.
N1335 X12.5
N1340 X12.
N1345 X11.5
N1350 X11.
N1355 X10.5
N1360 X10.
N1365 X9.5
N1370 X9.
N1375 X8.5
N1380 X8.
N1385 X7.5
N1390 X7.
N1395 X6.5
N1400 X6.
N1405 X5.5
N1410 X5.
N1415 X4.5
N1420 X4.
N1425 X3.5
N1430 X3.
N1435 X2.5
N1440 X2.
N1445 X1.5
N1450 X1.
N1455 X0.5
N1460 Y5.75
N1465 X1.
N1470 X1.5
N1475 X2.
N1480 X2.5
N1485 X3.
N1490 X3.5
N1495 X4.
N1500 X4.5
N1505 X5.
N1510 X5.5
N1515 X6.
N1520 X6.5
N1525 X7.
N1530 X7.5
N1535 X8.
N1540 X8.5
N1545 X9.
N1550 X9.5
N1555 X10.
N1560 X10.5
N1565 X11.
N1570 X11.5
N1575 X12.
N1580 X12.5
N1585 X13.
N1590 X13.5
N1595 X14.
N1600 Y6.25
N1605 X13.5
N1610 X13.
N1615 X12.5
N1620 X12.
N1625 X11.5
N1630 X11.
N1635 X10.5
N1640 X10.
N1645 X9.5
N1650 X9.
N1655 X8.5
N1660 X8.
N1665 X7.5
N1670 X7.
N1675 X6.5
N1680 X6.
N1685 X5.5
N1690 X5.
N1695 X4.5
N1700 X4.
N1705 X3.5
N1710 X3.
N1715 X2.5
N1720 X2.
N1725 X1.5
N1730 X1.
N1735 X0.5
N1740 Y6.75
N1745 X1.
N1750 X1.5
N1755 X2.
N1760 X2.5
N1765 X3.
N1770 X3.5
N1775 X4.
N1780 X4.5
N1785 X5.
N1790 X5.5
N1795 X6.
N1800 X6.5
N1805 X7.
N1810 X7.5
N1815 X8.
N1820 X8.5
N1825 X9.
N1830 X9.5
N1835 X10.
N1840 X10.5
N1845 X11.
N1850 X11.5
N1855 X12.
N1860 X12.5
N1865 X13.
N1870 X13.5
N1875 X14.
N1880 Y7.25
N1885 X13.5
N1890 X13.
N1895 X12.5
N1900 X12.
N1905 X11.5
N1910 X11.
N1915 X10.5
N1920 X10.
N1925 X9.5
N1930 X9.
N1935 X8.5
N1940 X8.
N1945 X7.5
N1950 X7.
N1955 X6.5
N1960 X6.
N1965 X5.5
N1970 X5.
N1975 X4.5
N1980 X4.
N1985 X3.5
N1990 X3.
N1995 X2.5
N2000 X2.
N2005 X1.5
N2010 X1.
N2015 X0.5
N2020 Y7.75
N2025 X1.
N2030 X1.5
N2035 X2.
N2040 X2.5
N2045 X3.
N2050 X3.5
N2055 X4.
N2060 X4.5
N2065 X5.
N2070 X5.5
N2075 X6.
N2080 X6.5
N2085 X7.
N2090 X7.5
N2095 X8.
N2100 X8.5
N2105 X9.
N2110 X9.5
N2115 X10.
N2120 X10.5
N2125 X11.
N2130 X11.5
N2135 X12.
N2140 X12.5
N2145 X13.
N2150 X13.5
N2155 X14.
N2160 Y8.25
N2165 X13.5
N2170 X13.
N2175 X12.5
N2180 X12.
N2185 X11.5
N2190 X11.
N2195 X10.5
N2200 X10.
N2205 X9.5
N2210 X9.
N2215 X8.5
N2220 X8.
N2225 X7.5
N2230 X7.
N2235 X6.5
N2240 X6.
N2245 X5.5
N2250 X5.
N2255 X4.5
N2260 X4.
N2265 X3.5
N2270 X3.
N2275 X2.5
N2280 X2.
N2285 X1.5
N2290 X1.
N2295 X0.5
N2300 Y8.75
N2305 X1.
N2310 X1.5
N2315 X2.
N2320 X2.5
N2325 X3.
N2330 X3.5
N2335 X4.
N2340 X4.5
N2345 X5.
N2350 X5.5
N2355 X6.
N2360 X6.5
N2365 X7.
N2370 X7.5
N2375 X8.
N2380 X8.5
N2385 X9.
N2390 X9.5
N2395 X10.
N2400 X10.5
N2405 X11.
N2410 X11.5
N2415 X12.
N2420 X12.5
N2425 X13.
N2430 X13.5
N2435 X14.
N2440 Y9.25
N2445 X13.5
N2450 X13.
N2455 X12.5
N2460 X12.
N2465 X11.5
N2470 X11.
N2475 X10.5
N2480 X10.
N2485 X9.5
N2490 X9.
N2495 X8.5
N2500 X8.
N2505 X7.5
N2510 X7.
N2515 X6.5
N2520 X6.
N2525 X5.5
N2530 X5.
N2535 X4.5
N2540 X4.
N2545 X3.5
N2550 X3.
N2555 X2.5
N2560 X2.
N2565 X1.5
N2570 X1.
N2575 X0.5
N2580 Y9.75
N2585 X1.
N2590 X1.5
N2595 X2.
N2600 X2.5
N2605 X3.
N2610 X3.5
N2615 X4.
N2620 X4.5
N2625 X5.
N2630 X5.5
N2635 X6.
N2640 X6.5
N2645 X7.
N2650 X7.5
N2655 X8.
N2660 X8.5
N2665 X9.
N2670 X9.5
N2675 X10.
N2680 X10.5
N2685 X11.
N2690 X11.5
N2695 X12.
N2700 X12.5
N2705 X13.
N2710 X13.5
N2715 X14.
N2720 Y10.25
N2725 X13.5
N2730 X13.
N2735 X12.5
N2740 X12.
N2745 X11.5
N2750 X11.
N2755 X10.5
N2760 X10.
N2765 X9.5
N2770 X9.
N2775 X8.5
N2780 X8.
N2785 X7.5
N2790 X7.
N2795 X6.5
N2800 X6.
N2805 X5.5
N2810 X5.
N2815 X4.5
N2820 X4.
N2825 X3.5
N2830 X3.
N2835 X2.5
N2840 X2.
N2845 X1.5
N2850 X1.
N2855 X0.5
N2860 Y14.75
N2865 X1.
N2870 X1.5
N2875 X2.
N2880 X2.5
N2885 X3.
N2890 X3.5
N2895 X4.
N2900 X4.5
N2905 X5.
N2910 X5.5
N2915 X6.
N2920 X6.5
N2925 X7.
N2930 X7.5
N2935 X8.
N2940 X8.5
N2945 X9.
N2950 X9.5
N2955 X10.
N2960 X10.5
N2965 X11.
N2970 X11.5
N2975 X12.
N2980 X12.5
N2985 X13.
N2990 X13.5
N2995 X14.
N3000 Y15.25
N3005 X13.5
N3010 X13.
N3015 X12.5
N3020 X12.
N3025 X11.5
N3030 X11.
N3035 X10.5
N3040 X10.
N3045 X9.5
N3050 X9.
N3055 X8.5
N3060 X8.
N3065 X7.5
N3070 X7.
N3075 X6.5
N3080 X6.
N3085 X5.5
N3090 X5.
N3095 X4.5
N3100 X4.
N3105 X3.5
N3110 X3.
N3115 X2.5
N3120 X2.
N3125 X1.5
N3130 X1.
N3135 X0.5
N3140 Y17.75
N3145 X1.
N3150 X1.5
N3155 X2.
N3160 X2.5
N3165 X3.
N3170 X3.5
N3175 X4.
N3180 X4.5
N3185 X5.
N3190 X5.5
N3195 X6.
N3200 X6.5
N3205 X7.
N3210 X7.5
N3215 X8.
N3220 X8.5
N3225 X9.
N3230 X9.5
N3235 X10.
N3240 X10.5
N3245 X11.
N3250 X11.5
N3255 X12.
N3260 X12.5
N3265 X13.
N3270 X13.5
N3275 X14.
N3280 Y18.25
N3285 X13.5
N3290 X13.
N3295 X12.5
N3300 X12.
N3305 X11.5
N3310 X11.
N3315 X10.5
N3320 X10.
N3325 X9.5
N3330 X9.
N3335 X8.5
N3340 X8.
N3345 X7.5
N3350 X7.
N3355 X6.5
N3360 X6.
N3365 X5.5
N3370 X5.
N3375 X4.5
N3380 X4.
N3385 X3.5
N3390 X3.
N3395 X2.5
N3400 X2.
N3405 X1.5
N3410 X1.
N3415 X0.5
N3420 X14. Y17.25
N3425 X13.5
N3430 X13.
N3435 X12.5
N3440 X12.
N3445 X11.5
N3450 X11.
N3455 X10.5
N3460 X10.
N3465 X9.5
N3470 X9.
N3475 X8.5
N3480 X8.
N3485 X7.5
N3490 X7.
N3495 X6.5
N3500 X6.
N3505 X5.5
N3510 X5.
N3515 X4.5
N3520 X4.
N3525 X3.5
N3530 X3.
N3535 X2.5
N3540 X2.
N3545 X1.5
N3550 X1.
N3555 X0.5
N3560 Y16.75
N3565 X1.
N3570 X1.5
N3575 X2.
N3580 X2.5
N3585 X3.
N3590 X3.5
N3595 X4.
N3600 X4.5
N3605 X5.
N3610 X5.5
N3615 X6.
N3620 X6.5
N3625 X7.
N3630 X7.5
N3635 X8.
N3640 X8.5
N3645 X9.
N3650 X9.5
N3655 X10.
N3660 X10.5
N3665 X11.
N3670 X11.5
N3675 X12.
N3680 X12.5
N3685 X13.
N3690 X13.5
N3695 X14.
N3700 Y16.25
N3705 X13.5
N3710 X13.
N3715 X12.5
N3720 X12.
N3725 X11.5
N3730 X11.
N3735 X10.5
N3740 X10.
N3745 X9.5
N3750 X9.
N3755 X8.5
N3760 X8.
N3765 X7.5
N3770 X7.
N3775 X6.5
N3780 X6.
N3785 X5.5
N3790 X5.
N3795 X4.5
N3800 X4.
N3805 X3.5
N3810 X3.
N3815 X2.5
N3820 X2.
N3825 X1.5
N3830 X1.
N3835 X0.5
N3840 Y15.75
N3845 X1.
N3850 X1.5
N3855 X2.
N3860 X2.5
N3865 X3.
N3870 X3.5
N3875 X4.
N3880 X4.5
N3885 X5.
N3890 X5.5
N3895 X6.
N3900 X6.5
N3905 X7.
N3910 X7.5
N3915 X8.
N3920 X8.5
N3925 X9.
N3930 X9.5
N3935 X10.
N3940 X10.5
N3945 X11.
N3950 X11.5
N3955 X12.
N3960 X12.5
N3965 X13.
N3970 X13.5
N3975 X14.
N3980 Y14.25
N3985 X13.5
N3990 X13.
N3995 X12.5
N4000 X12.
N4005 X11.5
N4010 X11.
N4015 X10.5
N4020 X10.
N4025 X9.5
N4030 X9.
N4035 X8.5
N4040 X8.
N4045 X7.5
N4050 X7.
N4055 X6.5
N4060 X6.
N4065 X5.5
N4070 X5.
N4075 X4.5
N4080 X4.
N4085 X3.5
N4090 X3.
N4095 X2.5
N4100 X2.
N4105 X1.5
N4110 X1.
N4115 X0.5
N4120 Y13.75
N4125 X1.
N4130 X1.5
N4135 X2.
N4140 X2.5
N4145 X3.
N4150 X3.5
N4155 X4.
N4160 X4.5
N4165 X5.
N4170 X5.5
N4175 X6.
N4180 X6.5
N4185 X7.
N4190 X7.5
N4195 X8.
N4200 X8.5
N4205 X9.
N4210 X9.5
N4215 X10.
N4220 X10.5
N4225 X11.
N4230 X11.5
N4235 X12.
N4240 X12.5
N4245 X13.
N4250 X13.5
N4255 X14.
N4260 Y12.25
N4265 X13.5
N4270 X13.
N4275 X12.5
N4280 X12.
N4285 X11.5
N4290 X11.
N4295 X10.5
N4300 X10.
N4305 X9.5
N4310 X9.
N4315 X8.5
N4320 X8.
N4325 X7.5
N4330 X7.
N4335 X6.5
N4340 X6.
N4345 X5.5
N4350 X5.
N4355 X4.5
N4360 X4.
N4365 X3.5
N4370 X3.
N4375 X2.5
N4380 X2.
N4385 X1.5
N4390 X1.
N4395 X0.5
N4400 Y12.75
N4405 X1.
N4410 X1.5
N4415 X2.
N4420 X2.5
N4425 X3.
N4430 X3.5
N4435 X4.
N4440 X4.5
N4445 X5.
N4450 X5.5
N4455 X6.
N4460 X6.5
N4465 X7.
N4470 X7.5
N4475 X8.
N4480 X8.5
N4485 X9.
N4490 X9.5
N4495 X10.
N4500 X10.5
N4505 X11.
N4510 X11.5
N4515 X12.
N4520 X12.5
N4525 X13.
N4530 X13.5
N4535 X14.
N4540 Y13.25
N4545 X13.5
N4550 X13.
N4555 X12.5
N4560 X12.
N4565 X11.5
N4570 X11.
N4575 X10.5
N4580 X10.
N4585 X9.5
N4590 X9.
N4595 X8.5
N4600 X8.
N4605 X7.5
N4610 X7.
N4615 X6.5
N4620 X6.
N4625 X5.5
N4630 X5.
N4635 X4.5
N4640 X4.
N4645 X3.5
N4650 X3.
N4655 X2.5
N4660 X2.
N4665 X1.5
N4670 X1.
N4675 X0.5
N4680 Y11.75
N4685 X1.
N4690 X1.5
N4695 X2.
N4700 X2.5
N4705 X3.
N4710 X3.5
N4715 X4.
N4720 X4.5
N4725 X5.
N4730 X5.5
N4735 X6.
N4740 X6.5
N4745 X7.
N4750 X7.5
N4755 X8.
N4760 X8.5
N4765 X9.
N4770 X9.5
N4775 X10.
N4780 X10.5
N4785 X11.
N4790 X11.5
N4795 X12.
N4800 X12.5
N4805 X13.
N4810 X13.5
N4815 X14.
N4820 Y11.25
N4825 X13.5
N4830 X13.
N4835 X12.5
N4840 X12.
N4845 X11.5
N4850 X11.
N4855 X10.5
N4860 X10.
N4865 X9.5
N4870 X9.
N4875 X8.5
N4880 X8.
N4885 X7.5
N4890 X7.
N4895 X6.5
N4900 X6.
N4905 X5.5
N4910 X5.
N4915 X4.5
N4920 X4.
N4925 X3.5
N4930 X3.
N4935 X2.5
N4940 X2.
N4945 X1.5
N4950 X1.
N4955 X0.5
N4960 Y10.75
N4965 X1.
N4970 X1.5
N4975 X2.
N4980 X2.5
N4985 X3.
N4990 X3.5
N4995 X4.
N5000 X4.5
N5005 X5.
N5010 X5.5
N5015 X6.
N5020 X6.5
N5025 X7.
N5030 X7.5
N5035 X8.
N5040 X8.5
N5045 X9.
N5050 X9.5
N5055 X10.
N5060 X10.5
N5065 X11.
N5070 X11.5
N5075 X12.
N5080 X12.5
N5085 X13.
N5090 X13.5
N5095 X14.
N5100 G80
N5105 G0 Z0.64
N5110 G53 Z0.
N5115 G53 X0. Y0.
N5120 M30
When I load the program I get an error Program exceeds machine maximum on Axis Z my stepconfig table travel is X 0.0 to 14.5 Y 0.0 tp 20.0 Z -3.5 to 0.0 When I view the program in the Linuxcnc preview I can see its out of the Z axis for height but I'm stumped as to why. Any help would be appreciated -ed
