- Mute
- Permalink
- Report
Hi!
I've been using fusion360 for some time now, and its been great. However I have run in to this issue that appears to be independent of the file I first found it in. I've taken some screenshots below to describe the problem, but the general issue is that fusion seems to let me select the features I want to extrude, but after I hit "ok" it only extrudes a portion of them. Really not certain what is going on here, any help/suggestions would be appreciated.
EDIT 1: I should say that I can extrude the features that didn't get extruded in a second extrude operation, but I can't seem to get all the features to extrude in one operation.
EDIT 2: It seems to be that fusion is de-selecting some of the sketch regions selected in the extrude operation. When you double click on the erroring extrude in the timeline to edit it, it shows that the only selected regions are the ones that it did extrude, not the ones that were originally selected.
Sketch before extrude:
In the extrude dialog selecting regions to extrude on said sketch:
After hitting "ok" in the extrude dialog:
