Possible Bug when editing sketch
mikelerwill
Message 1 of 9
mikelerwill
Hi
The attached file has four items in the timeline, sketch,extrude,sketch,extrude. The second pair are currently suppressed.
If I open the file and unsuppress the two items and then edit the sketch nothing appears.
To be able to edit the sketch I have to first save with the features unsuppressed then close and reopen the design.
Can someone confirm if this is a bug or if I am doing something wrong.
Mike Lerwill
Replies (8)
Message 2 of 9
TheCADWhisperer
Looks like a bug to me.
Message 3 of 9
mikelerwill
Thanks theCADWhisperer, How do I ensure this has got the attention of someone at Autodesk, while it is easy to work around it would be nice to get it fixed someday.
I realise I may have been better off posting this in the support forum but there does not seem to be a way of moving it.
Message 4 of 9
TheCADWhisperer
I doubt that much gets missed here.
The issue was probably noted.
Message 5 of 9
TheCADWhisperer
However, I wouldn't mark it as solved until someone from Autodesk comes along and verifies that they can reproduce the issue.  I noticed that I the only one who verified reproduction of the issue.
Message 6 of 9
TrippyLighting
Let's see if we can bring this to their attention: @ryan.bales
Message 7 of 9
ryan.bales
Autodesk Support
Autodesk Support
Thanks @TrippyLighting, good to be back in the forums after a vacation!
That is strange, probably a good idea to tag @jeff_strater as well. I think he and have seen this before but that model was for more complex than this one.
@mikelerwill, is this a one off case or does this happen easily from a new file?
Ryan Bales
Fusion 360 Product Support
Message 8 of 9
mikelerwill
Ryan,
The file supplied was created from scratch simply to demonstrate. The problem was originally discovered in a more complex part and occurs the same way in two designs.
regards
Mike Lerwill
Message 9 of 9
jeff_strater
yes, this is a known bug:  FUS-35158.  I'll ping the team on the status of it...  Thanks for reporting this.
Jeff Strater
Engineering Director
