I'm trying to design a solar panel pergoda, and I'm struggling with positioning of parts. Advice would be gratefully received. This is what I'm doing:
1/ Draw a solar panel as a 'New Design'.
2/ Drag (I'm not sure of the proper term for this, but I drag it in from the project browser on the right) this into a new design and make a rectangular pattern (based on user parameters). Then make a rigid group of the array.
3/ (This is where I get stuck). I again 'drag' this into a new design, and I want to position it with one edge a parameterised height above the XY plane, and co(planar?, if a line and a plane can be coplanar) with the YZ plane (see edge below). Which will determine one of the two heights of the sloping (pent) roof.
And I want to position an opposing edge at a (slightly higher in this case) height above the XY plane, to define the highest edge of the pent roof.
Also, I guess after this it would have one remaining degree of freedom, so I'd need to put an edge like below coplanar with the XZ plane.
Here's what I'm aiming for:
I then want to design the frame around (referenced to) this 'floating' array, such that the frame adjusts as and when i adjust the h1 and h2 user parameters.
I've attached the fusion design into which the array was 'dragged'.
I'd really appreciate any help you can give.
